[GRASS-user] script in python
Moritz Lennert
mlennert at club.worldonline.be
Mon Dec 1 10:10:18 EST 2008
On 01/12/08 15:55, Gabriele Nolè wrote:
> Moritz Lennert-2 wrote:
>> On 01/12/08 15:23, Gabriele Nolè wrote:
>>> Hi Jose.
>>> I changed the code by trying different solutions, such as:
>>> def main():
>>> vect1 = options['vect_1']
>>> vect2 = options['vect_2']
>>> vect3 = options['vect_3']
>>> vbuffer=subprocess.Popen('v.buffer','input=vect_1','output=buffer_200m','buffer=200')
>>> retcode=vbuffer.wait()
>>> # Then I also tried with another command (v.db.addcol):
>>> #import subprocess
>>> #vaddcol=subprocess.Popen('v.db.addcol','map=vect_1','columns=prova','VARCHAR(15)')
>> The parameter for v.db.addcol is columns='prova varchar(15)'. I don't
>> think you can split that up into two parameters. Shouldn't this be:
>> VARCHAR(15)')
>> (don't know if the white space is allowed as such or whether you need to
>> quote the entire parameter as "prova VARCHAR(15)")
>> Moritz
> Yes, I have tried in this way but not right (with 'columns=prova
> VARCHAR(15)').
> Now I have also tried to remove white space but ... nothing
As Glynn has already said: check the existing scripts in trunk[1]. E.g.
in v.rast.stats.py:
if i == "n":
coltype = "INTEGER"
else:
coltype = "DOUBLE PRECISION"
addcols.append(currcolumn + ' ' + coltype)
if addcols:
grass.verbose("Adding columns <%s>" % addcols)
if grass.run_command('v.db.addcol', map = vector, columns =
addcols) != 0:
Moritz
[1] http://trac.osgeo.org/grass/browser/grass/trunk/scripts
