[GRASS-user] G_malloc: out of memory
Adam Dershowitz adershowitz at exponent.com
Mon Dec 1 13:46:46 EST 2008
On Nov 23, 2008, at 12:42 PM, William Kyngesburye wrote:
> On Nov 22, 2008, at 7:42 PM, Kurt Springs wrote:
>> Okay, I'm willing to try.  I hope 6.4 will help in getting nodes to
>> snap.
>> Kurt
>> On Nov 22, 2008, at 11:22 AM, William Kyngesburye wrote:
>>> I'm somewhat caught up on other distractions and can focus more on
>>> GRASS again.  I can package up a 6.4svn.
>>> If your up to it, there are detailed OSX compile instructions in
>>> the source, though I should look them over for any changes needed.
> I have 6.4 SVN binaries online now.  Tested on Leopard so far.  I
> also updated the build instructions in the source.
> A couple important changes from my previous binaries (the build
> instructions also reflect these changes):
> - It uses ActiveTcl 8.5 now for the TclTk GUI and NVIZ.  This "aqua-
> fies" the TclTk GUI.  The X11 TclTk is not bundled now and not needed.
> - It uses up-to-date wxPython binaries, even on Leopard.  Starting
> with wxPython 2.8.8, it can install to be used with the Leopard
> system Python 2.5 as well as the python.org Python.  This may
> interfere with the wx gui in GRASS 6.3, but it's not as well
> developed anyways.
I downloaded this.  So far the basics seem fine, but I get an error
when I try to use nviz.  The error is below:
Process:         nviz [5420]
Path:            /Applications/GRASS-6.4.app/Contents/MacOS/etc/
nviz2.2/nviz
Identifier:      nviz
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  wish [5215]
Date/Time:       2008-12-01 10:40:24.737 -0800
OS Version:      Mac OS X 10.5.5 (9F33)
Report Version:  6
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread:  0
Dyld Error Message:
   Library not loaded: /Library/Frameworks/Tk.framework/Versions/8.5/Tk
   Referenced from: /Applications/GRASS-6.4.app/Contents/MacOS/etc/
nviz2.2/nviz
   Reason: image not found
Do I have to separately install a new version of TclTK?  I have both
whatever is installed with the default 10.5.5, and I also use MacPorts
and I have tcl 8.5.5 and tk 8.5.5 installed from Macports.
Do I need to install something else?  Or is nviz just looking in the
wrong place and needs to get pointed in the right direction?
Thanks,
--Adam
