[GRASS-user] Going back to 6.3
    Adam Dershowitz
    adershowitz at exponent.com
    Mon Dec  1 14:57:07 EST 2008
On Dec 1, 2008, at 11:51 AM, Adam Dershowitz wrote:
> On Nov 25, 2008, at 8:51 PM, William Kyngesburye wrote:
>> On Nov 25, 2008, at 10:33 PM, Kurt Springs wrote:
>>>> If you are using my GRASS 6.3, there is no need to delete
>>>> ActiveTcl.  It has its own internal TclTk X11 binaries that it
>>>> explicitly uses.  In fact, no need to delete 6.3 before
>>>> installing 6.4.
>>> 6.4 actually overwrote 6.3.  I'd assumed the reverse would be true.
>> Odd, GRASS 6.3 and 6.4 have different names:
>> GRASS-6.3.app
>> GRASS-6.4.app
> I can confirm that the 6.4 install doesn't actually delete
> GRASS-6.3.app, it just "empties" it out.  So that it is now 6.5 meg,
> while it used to be much larger (6.4 is 74 meg).  And when I double
> click on 6.3 I get a error in my log:
> posix_spawnp("/Applications/GRASS-6.3.app/Contents/MacOS/
> GRASS", ...): No such file or directory
> So it looks like the 6.4 installer deletes most, but not all, of the
> stuff that was in 6.3._______________________________________________
I just tested it and just re-installing 6.3, while 6.4 is there, seems
to allow both to coexist fine.
