Re: [GRASS-user] Elevation profile from intersecting shapefiles
georgew
gws293 at hotmail.com
Wed Dec 3 01:25:01 EST 2008
Micha, I followed your instructions with the following results:
Import data from 2 shapefiles, Contour (layer 1)and Track (layer 2): (no
problems reported)
v.in.ogr dsn=/home/george/GRASSDATA/ output=testvectmap min_area=0.0001
snap=-1
Display vector map: (no problems, map displayes correctly)
d.vect map=testvectmap at testvector color=0:0:0 lcolor=0:0:0
fcolor=170:170:170 display=shape type=point,line,boundary,area
icon=basic/circle size=5 layer=-1 lsize=8 xref=left yref=center llayer=1
Convert vector to raster and thin: (no problems reported)
v.to.rast input=testvectmap at testvector output=testrastmap use=attr
type=point,line,area layer=1 column=ELEVATION value=1 rows=100000
r.thin input=testrastmap at testvector output=thinrastmap iterations=200
Display raster map (PROBLEM:only displays large, brightly coloured
rectangles, no contours
d.rast map=testrastmap at testvector -o
At this point I stopped as I got the impression something was already wrong
but could not work out what.
Also, should I not rasterize the track data as well?
Any help would be appreciated. If you require the source shapefiles I have
no problems sending them to you.
Micha Silver wrote:
> Yes.
> I think you should be looking at converting the shapefile contour lines
> to a raster....
> v.in.org to import the contour lines and tracks into grass
> v.to.rast and r.thin to convert the contour lines to a raster map.
> r.surf.contour to create an elevation surface from the rasterized
> contours
> r.profile to get the elevations along the tracks.
> Post back with specific questions if you hit a snag.
> Regards,
> Micha
> ___________________________________________
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://www.nabble.com/Elevation-profile-from-intersecting-shapefiles%E2%80%8F-tp20744104p20803902.html
Sent from the Grass - Users mailing list archive at Nabble.com.
