[GRASS-user] Using GRASS for non-geographical spatial data
Carl Trapani carl at skytopsoftware.com
Wed Dec 3 12:41:58 EST 2008
Hello GRASS users,
I am wondering if there is anyone out there using GRASS with
non-geographical, spatial data? Specifically, the integration and
rectification of raster and vector data which is NOT geographically
referenced.
We are trying to build a 3D visualization application of gene expression
data from the mouse cerebellum, from embryo through day 12 after birth.
The gene expression data are spots from cross sectioned tissues, or
"raster data" with no geographical reference/projection. These raster
sections must be aligned (registered) with each other and then
transformed (scaled, rotated, translated -- in GIS speak: rectified?) to
fit into a 3D model (vector) containing surface meshes marking
anatomical features of the cerebellum (exterior surface, cell layers,
etc...).
Although I don't know much about the details of GIS or GRASS, it seems
to me that GIS (and GRASS by extension) has handled this mix and match
and rectification of raster and vector representations very well, but
this functionality is based on defined and translatable geological
projections and coordinate systems. Will the functionality work when the
reference coordinate system is generic or home spun?
Are we swimming up stream if we try and stuff this data into GRASS or
could it work? Your thoughts would be much appreciated.
(ASIDE: Isn't this always what happens in software? You build someone a
shoe, a good shoe, for walking on land. Then, someone comes along and
asks "Hey, I could walk on water with that shoe, couldn't I?" ;-)
Thanks,
Carl Trapani
Skytop Software
