[GRASS-user] Using GRASS for non-geographical spatial data
Moritz Lennert mlennert at club.worldonline.be
Wed Dec 3 17:20:16 EST 2008
Carl Trapani wrote:
> Hello GRASS users,
> I am wondering if there is anyone out there using GRASS with
> non-geographical, spatial data? Specifically, the integration and
> rectification of raster and vector data which is NOT geographically
> referenced.
> We are trying to build a 3D visualization application of gene expression
> data from the mouse cerebellum, from embryo through day 12 after birth.
> The gene expression data are spots from cross sectioned tissues, or
> "raster data" with no geographical reference/projection. These raster
> sections must be aligned (registered) with each other and then
> transformed (scaled, rotated, translated -- in GIS speak: rectified?) to
> fit into a 3D model (vector) containing surface meshes marking
> anatomical features of the cerebellum (exterior surface, cell layers,
> etc...).
> Although I don't know much about the details of GIS or GRASS, it seems
> to me that GIS (and GRASS by extension) has handled this mix and match
> and rectification of raster and vector representations very well, but
> this functionality is based on defined and translatable geological
> projections and coordinate systems. Will the functionality work when the
> reference coordinate system is generic or home spun?
> Are we swimming up stream if we try and stuff this data into GRASS or
> could it work? Your thoughts would be much appreciated.
Several people have used GRASS with local archeology data, and others
have used traditional (i.e. only locally referenced) cadastral data in
GRASS, so I don't see why you shouldn't be able to use it.
AFAIK, you will need some sort of projection system to be able to use
tools like i.rectify, but since you are working at an extremely large
scale (sub-centimetric I would suppose), I actually suspect that you
could probably use any arbitrary existing projection system as there
would be no difference between them at that scale.
Moritz
