Re: [GRASS-user] Elevation profile from intersecting shapefiles‏
Thu Dec 4 05:23:47 EST 2008
Hamish wrote:
> A symptom of the computational region being way out of whack compared to
> your display region is that you see the result as a series of huge blocks
> (computational resolution is too coarse), or in the other direction the
> resolution is so fine that takes ages to load. YMMV
Note that a mismatch between computational and display regions isn't
necessarily "wrong". You may want to perform computations at a
resolution finer than that of the display for accuracy, or coarser
than it for speed.
