[GRASS-user] r.neighbors, wide filtering
John Stevenson john.stevenson at manchester.ac.uk
Thu Dec 4 13:37:56 EST 2008
For my research, I am testing a mesh denoising algorithm on topographic
data.  It smooths the surfaces much like using r.neighbors
method=average or r.neighbors method=median, and, depending on
settings,  gives similar results to r.neighbors when size <5.  The
advantage of the algorithm is that it has some ability to preserve
features.  In cases where more significant smoothing is necessary
(r.neighbors size > 5) it is much better at preserving minimum and
maximum elevations etc as it converges on a stable solution for the
smoothed landscape.
My question relates to understanding in which cases is it necessarily to
smooth to such an extent?  From what I have seen e.g. taking speckle out
of SRTM DEMs, smoothing by such extremes removes a lot of useful
information and results in unrealistic surfaces.
Has anyone come across a situation/dataset or type of analysis where
they need to smooth with r.neighbors (method=average/median, size > 5)?
I would be interested to know, and to see if this algorithm would be useful.
Cheers
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
