[GRASS-user] How to make a LOCATION corresponding to JGD2000 CS
	III
    Hamish
    hamish_b at yahoo.com
    Fri Dec  5 22:02:52 EST 2008
Masayuki Naruse wrote:
> I want to create a LOCATION corresponding to JGD2000 CS III
> which is defined in epsg.
in the GUI startup you could try "create new location from EPSG code",
or the same from within another grass location with 'g.proj loc= epsg='
> I tried to create it as following,
> coordinate system : Other Projection
> projection name : tmerc
> geodetic datum : custom
> ellipsoid name : GRS80
> towgs84=0,0,0,0,0,0,0
> Scale Factor : 0.9999
> Central Parallel : 36N
> But I could not input the next item "Central Meridian".
> In epsg definition, the central meridian of JGD2000 CS III is
> "+lon_0=132.1666666666667", so an error message was appeared.
> The message is "132.1666666666667E is invalid for longitude".
try 132.1666666666667 (decimal form uses +/- not E/W), or 132:10E.
Hamish
