[GRASS-user] raster data from one location to another
Daniel Victoria
daniel.victoria at gmail.com
Thu Dec 11 11:24:19 EST 2008
To transfer from one location to another take a look at r.proj
It's used to do projection transformation and it does so by copying
from one location to another.... I guess it should work if both
locations have the same projection, that is, copy from one location to
another
DAniel
On Thu, Dec 11, 2008 at 12:23 PM, José María Michia
<jose.maria.michia at gmail.com> wrote:
> Hi list. Sorry for the very basic question. I can not find a convincing way
> to do it myself.
> I need to copy a raster map from one location to another. I've think this
> options:
> - use a intermediary format, like ASCII
> - use r.pack/r.unpack
> - copy manually the files needed. I think that the files needed are all
> files named with the same name that the source layer, and that are under
> directories named "*cell*"
> I've searched in google and in documentation, but I'm sure that exist some
> better solution. Thanks for any advice.
> Saludos
> José María
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
