[GRASS-user] raster data from one location to another
Hamish hamish_b at yahoo.com
Fri Dec 12 04:02:13 EST 2008
Daniel wrote:
> To transfer from one location to another take a look at r.proj
> It's used to do projection transformation and it does so by copying
> from one location to another.... I guess it should work if both
> locations have the same projection, that is, copy from one location to
> another
if the projections are the same, I'd just create a new mapset, g.copy
the map(s) into it with 'g.copy map at othermapset,map', then move the mapset
directory over.
not ideal, but it works better than anything else.
Hamish
