[GRASS-user] raster data from one location to another
José María Michia jose.maria.michia at gmail.com
Fri Dec 12 04:16:27 EST 2008
2008/12/12 Hamish <hamish_b en yahoo.com>:
> Daniel wrote:
>> To transfer from one location to another take a look at r.proj
>> It's used to do projection transformation and it does so by copying
>> from one location to another.... I guess it should work if both
>> locations have the same projection, that is, copy from one location to
>> another
> if the projections are the same, I'd just create a new mapset, g.copy
> the map(s) into it with 'g.copy map en othermapset,map', then move the mapset
> directory over.
> not ideal, but it works better than anything else.
> Hamish
This solution sounds more indicated to my original problem. I not need
anymore this operation. At least for now, I have much exciting GRASS
work to the future.
Thank very much Hamish, and all list people.
José María
