[GRASS-user] Re: Landsat data archive now free
Glynn Clements
glynn at gclements.plus.com
Sun Dec 14 08:34:54 EST 2008
Richard Chirgwin wrote:
> > 1 - on opening GRASS GIS, select create location from georeferenced file
> > 2 - use r.in.gdal to import in GRASS GIS.
> ...works fine...
> > 3 - in grass/add-ons look for any of these to correct from radiance to
> > reflectance at top of atmoshpere
> > - raster/i.landsat.toar
> > - gipe/i.dn2full.l5
> > - gipe/i.dn2full.l7
> Yann, there is something I can't work out from the reference documents,
> and the result is that install_yann_grass.sh fails because it can't find
> the right directories. Full fail output is:
> > Makefile.gipe:13: ../include/Make/Platform.make: No such file or directory
> > Makefile.gipe:17: ../include/Make/Dir.make: No such file or directory
You need to set MODULE_TOPDIR to the top-level GRASS installation
directory (or a GRASS source directory where configure has been run),
e.g.:
make MODULE_TOPDIR=/usr/local/grass-6.4.svn ...
