[GRASS-user] Re: Landsat data archive now free
Yann Chemin yann.chemin at gmail.com
Sun Dec 14 08:44:42 EST 2008
Hello Richard,
You also could copy grass-adddons/imagery/i.landsat.toar to your
grass-svn/imagery/
inside grass-svn/imagery/Makefile add i.landsat.toar in the list of
subdir to make.
You eventtually can just make;make install your grass-svn.
I believe in install_yanns_grass.sh there are two directory paths to
adjust to yours...
Yann
2008/12/13 Richard Chirgwin <rchirgwin at ozemail.com.au>:
> Yann Chemin wrote:
>> Hi,
>> 1 - on opening GRASS GIS, select create location from georeferenced file
>> 2 - use r.in.gdal to import in GRASS GIS.
> ...works fine...
>> 3 - in grass/add-ons look for any of these to correct from radiance to
>> reflectance at top of atmoshpere
>> - raster/i.landsat.toar
>> - gipe/i.dn2full.l5
>> - gipe/i.dn2full.l7
> Yann, there is something I can't work out from the reference documents,
> and the result is that install_yann_grass.sh fails because it can't find
> the right directories. Full fail output is:
>> Makefile.gipe:13: ../include/Make/Platform.make: No such file or directory
>> Makefile.gipe:17: ../include/Make/Dir.make: No such file or directory
>> make: *** No rule to make target `../include/Make/Dir.make'.  Stop.
>> cp: cannot stat `/home/richard/grass-addons/i.*': No such file or
>> directory
>> Makefile.gipe:3: ..//include/Make/Dir.make: No such file or directory
>> make: *** No rule to make target `..//include/Make/Dir.make'.  Stop.
>> cp: cannot create regular file
>> `/home/richard/tmp/grass_yann/gui/tcltk/gis.m/': No such file or directory
>> `/home/richard/tmp/grass_yann/gui/wxpython/gui_modules/': No such file
>> or directory
>> ./install_yanns_grass.sh: line 75: cd:
>> /home/richard/tmp/grass_yann/gui: No such file or directory
>> Makefile:8: ../../include/Make/Module.make: No such file or directory
>> make: *** No rule to make target `../../include/Make/Module.make'.  Stop.
>> make: *** No rule to make target `install'.  Stop.
> Cheers,
> Richard
>> 4 - use i.atcorr too correct top of atmosphere to surface reflectance.
>> good luck!
>> Yann
>> 2008/12/12 Richard Chirgwin <rchirgwin at ozemail.com.au>:
>>>> Message: 2
>>>> Date: Fri, 12 Dec 2008 11:13:36 +0000
>>>> From: Corrado <ct529 at york.ac.uk>
>>>> Subject: Re: [GRASS-user] LANDSAT data archive now free
>>>> To: grass-user at lists.osgeo.org
>>>> Message-ID: <200812121113.36391.ct529 at york.ac.uk>
>>>> Content-Type: text/plain;  charset="utf-8"
>>>> Dear grasslings,
>>>> I was not able to understand whether there was any information provided with
>>>> the images, or only the images.
>>>> Best,
>>> I have this dreadful feeling I'm going to expose my essential thickness
>>> here but ...
>>> It provides TIFFs and metadata in text files; is there an easy way to
>>> use these to import directly into a suitable location, or do I have to
>>> import-and-rectify?
>>> Richard C
>>> grass-user mailing list
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
