[GRASS-user] d.rast.edit does not save edited map although Save button is pressed
Hamish hamish_b at yahoo.com
Tue Dec 16 11:55:42 EST 2008
George:
> > >> Hi, I must be doing something wrong with the following:
> > >> The edited data is not saved in the output map
> > >> Any clues what I might be doing wrong. ?
Glynn:
> You can't enter values into the Value and Aspect fields on the top row
> (it may let you type into them, but it won't have any effect).
> You choose the new value either by right-clicking on a cell (to use
> that cell's value), or by typing the cell value into the Value field
> on the bottom row (to the left of the colour sample).
> You can then set cells to the chosen value by left-clicking on the
> cells.
perhaps this is a factor here:  http://trac.osgeo.org/grass/ticket/86
Hamish
