[GRASS-user] most recent kyngesburye build for osx tiger error
Brandon M. Gabler bgabler at email.arizona.edu
Thu Dec 18 14:46:05 EST 2008
Greetings all,
I recently installed Grass 6.3.0-3-Tig on my mac running Tiger, after
updating all necessary frameworks listed by William Kyngesburye.
Grass seems to start normally (though with lots of text at startup in
the terminal window, included at the end of this email), and it opens
the standard startup screen. I click Enter Grass, it spins a bit,
then this error in an X11 window: "Error setting region (Problem with
g.region?): child killed: trace trap", folled by this text in the
terminal window after I click the 'ok' button on the error window:
GRASS 6.3.0 (Brandon):~ > Error in startup script: can't read "parts
(w)": no such variable
     while executing
"set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
     (procedure "MapCanvas::zoom_gregion" line 16)
     invoked from within
"MapCanvas::zoom_gregion $mon"
     (procedure "MapCanvas::create" line 40)
     invoked from within
"MapCanvas::create"
     (procedure "Gm::startmon" line 11)
     invoked from within
"Gm::startmon"
     (procedure "Gm::create" line 79)
     invoked from within
"Gm::create"
     (procedure "main" line 30)
     invoked from within
"main $argc $argv"
     (file "/Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/gm.tcl"
line 541)
This occurs with multiple locations that have different projections,
bounds, etc.
I still have my older version, so I'm not in a pinch, but it would be
nice to get the newest version working and I'm lost on where to start.
Thanks much, and here is the text from startup (mentioned above) that
appears in the terminal window before the location selection screen
appears.
Last login: Thu Dec 18 12:42:51 on ttyp1
'/Applications/GRASS-6.3.app/Contents/MacOS/grass.sh'; exit
Welcome to Darwin!
brandon-gablers-computer:~ StrayHawk$ '/Applications/GRASS-6.3.app/
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
2008-12-18 12:43:30.271 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x32b5c0 of class NSPathStore2 autoreleased with no pool in
place - just leaking
2008-12-18 12:43:30.278 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x32e760 of class NSPathStore2 autoreleased with no pool in
Object 0x313570 of class NSCFString autoreleased with no pool in
Object 0x32e4e0 of class NSPathStore2 autoreleased with no pool in
Object 0x313c00 of class NSPathStore2 autoreleased with no pool in
Object 0x32df40 of class NSConcreteData autoreleased with no pool in
Object 0x32df60 of class NSCFArray autoreleased with no pool in place
- just leaking
2008-12-18 12:43:30.287 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x332730 of class NSPathStore2 autoreleased with no pool in
Object 0x32e2d0 of class NSBundle autoreleased with no pool in place
- just leaking
2008-12-18 12:43:30.288 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x330720 of class NSPathStore2 autoreleased with no pool in
Object 0x330930 of class NSCFString autoreleased with no pool in
Object 0x330810 of class NSPathStore2 autoreleased with no pool in
Object 0x330a90 of class NSPathStore2 autoreleased with no pool in
Object 0x3131b0 of class NSConcreteData autoreleased with no pool in
Object 0x3301c0 of class NSCFArray autoreleased with no pool in place
- just leaking
2008-12-18 12:43:30.291 osascript[10651] LCC Scroll Enhancer loaded
2008-12-18 12:43:30.291 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x331200 of class NSMachPort autoreleased with no pool in
2008-12-18 12:43:30.292 osascript[10651] *** _NSAutoreleaseNoPool():
Object 0x333c70 of class NSCFNumber autoreleased with no pool in
Object 0x3341c0 of class NSCFString autoreleased with no pool in
Object 0x3341d0 of class NSPathStore2 autoreleased with no pool in
Cleaning up temporary files.....
Starting GRASS ...
GISDBASE='/Users/StrayHawk/Murray_NZ';
LOCATION_NAME='NZ';
MAPSET='new_zealand';
GRASS GUI should be tcltk
