[GRASS-user] Re: most recent kyngesburye build for osx tiger error
William Kyngesburye woklist at kyngchaos.com
Thu Dec 18 18:33:19 EST 2008
On Dec 18, 2008, at 1:46 PM, Brandon M.Gabler wrote:
> Greetings all,
> I recently installed Grass 6.3.0-3-Tig on my mac running Tiger,
> after updating all necessary frameworks listed by William
> Kyngesburye. Grass seems to start normally (though with lots of text
> at startup in the terminal window, included at the end of this
> email), and it opens the standard startup screen. I click Enter
> Grass, it spins a bit, then this error in an X11 window: "Error
> setting region (Problem with g.region?): child killed: trace trap",
> folled by this text in the terminal window after I click the 'ok'
> button on the error window:
> GRASS 6.3.0 (Brandon):~ > Error in startup script: can't read
> "parts(w)": no such variable
>    while executing
> "set $parts(w) [expr round($parts(w)/$parts(ewres))*$parts(ewres)]"
>    (procedure "MapCanvas::zoom_gregion" line 16)
>    invoked from within
> "MapCanvas::zoom_gregion $mon"
>    (procedure "MapCanvas::create" line 40)
>    invoked from within
> "MapCanvas::create"
>    (procedure "Gm::startmon" line 11)
>    invoked from within
> "Gm::startmon"
>    (procedure "Gm::create" line 79)
>    invoked from within
> "Gm::create"
>    (procedure "main" line 30)
>    invoked from within
> "main $argc $argv"
>    (file "/Applications/GRASS-6.3.app/Contents/MacOS/etc/gm/gm.tcl"
> line 541)
Not sure about this part, I don't know much about the GUI internals.
> This occurs with multiple locations that have different projections,
> bounds, etc.
> I still have my older version, so I'm not in a pinch, but it would
> be nice to get the newest version working and I'm lost on where to
> start.
Does a d.mon (without the GUI) work to display anything?
> Thanks much, and here is the text from startup (mentioned above)
> that appears in the terminal window before the location selection
> screen appears.
> Last login: Thu Dec 18 12:42:51 on ttyp1
> '/Applications/GRASS-6.3.app/Contents/MacOS/grass.sh'; exit
> Welcome to Darwin!
> brandon-gablers-computer:~ StrayHawk$ '/Applications/GRASS-6.3.app/
> Rebuilding Addon HTML manual pages index...
> Rebuilding Addon menu...
> 2008-12-18 12:43:30.288 osascript[10651] *** _NSAutoreleaseNoPool():
> Object 0x3301c0 of class NSCFArray autoreleased with no pool in
> place - just leaking
> 2008-12-18 12:43:30.291 osascript[10651] LCC Scroll Enhancer loaded
> 2008-12-18 12:43:30.292 osascript[10651] *** _NSAutoreleaseNoPool():
> Object 0x3341d0 of class NSPathStore2 autoreleased with no pool in
> Cleaning up temporary files.....
> Starting GRASS ...
> GISDBASE='/Users/StrayHawk/Murray_NZ';
> LOCATION_NAME='NZ';
> MAPSET='new_zealand';
> GRASS GUI should be tcltk
That noise is either from some 3rd-party AppleScript scripting
addition you have installed, or from a system hack/extension (that LCC
Scroll Enahncer mentioned, maybe?) that may be a bit old, or poorly
programmed.  It is probably not affecting GRASS (CLI programs), since
AppleScript is only briefly used to start GRASS.  But it may
negatively affect X11 for the GUI...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
