[GRASS-user] suppress output to terminal completely
Hufkens Koen
koen.hufkens at ua.ac.be
Mon Dec 29 06:44:34 EST 2008
Hi list,
I'm working with r.le.patch in both scripts as well as interactively on the terminal.
Since these calculations take up a lot of time I would like to move them to the background.
If I use r.le.patch -mysettings & this will do just that.
However, the module still spews stuff to my terminal. This is very annoying as I login remotely so I can't fall back on the GUI menus.
Can I disable my terminal output completely?
dumping stout to /dev/null does not seem to work...
Any ideas, this would make GRASS workable again...
Cheers,
Koen
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081229/92b7c829/attachment.html
