[GRASS-user] copying mouse location to clipboard in gis.m
Moritz Lennert
mlennert at club.worldonline.be
Wed Dec 31 08:58:11 EST 2008
On Tue, December 30, 2008 19:07, pete davidson wrote:
> Ahh! That worked! Thanks so much. I'd looked in the output window
> before,
> but had missed the coordinates because I have so much attribute data tied
> to
> the map.
It would be nice to have the option to only query coordinates, not
attributes. Maybe you could add a wish to the tracker ?
Moritz
> Thanks again
> Peter
> On Sun, Dec 28, 2008 at 2:42 PM, Maciej Sieczka
> <msieczka at sieczka.org>wrote:
>> pete davidson pisze:
>>> Hi all
>>> In gis.m, as you mouse over a map, the current easting and northing
>>> is displayed in the lower right hand corner of the map window. This
>>> makes it easy to, for example, find the coordinates of an
>>> intersection on a street map by simply moving the cursor over the
>>> intersection and writing down the coordinates.
>>> My problem is, is there any way to copy those coordinates to the
>>> clipboard with a keystroke command so they can be pasted somewhere
>>> else, rather than having to write them down by hand? I've tried the
>>> usual ctrl-c / ctrl-x kind of things with the Pointer, Query, and
>>> Measure tools selected, but nothing I try seems to put anything on
>>> the clipboard.
>>> Does anyone know the answer to this one (or is there another way to
>>> do this using v.digit or something similar?)
>>> Here's a link to a screenshot with the coordinate box highlighted in
>>> case I haven't been clear:
>>> https://php10.ucsf.edu/ufostudy/transfer/screenshot.html
>> Query the map - the coordinates of where you clicked are in the gis.m
>> output window then, even if no object was found. Copy & paste from
>> there.
>> Maciek
>> Maciej Sieczka
>> www.sieczka.org
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
