[GRASS-user] copying mouse location to clipboard in gis.m
pete davidson
caitifty at gmail.com
Tue Dec 30 13:07:49 EST 2008
Ahh! That worked! Thanks so much. I'd looked in the output window before,
but had missed the coordinates because I have so much attribute data tied to
the map.
Thanks again
Peter
On Sun, Dec 28, 2008 at 2:42 PM, Maciej Sieczka <msieczka at sieczka.org>wrote:
> pete davidson pisze:
>> Hi all
>> In gis.m, as you mouse over a map, the current easting and northing
>> is displayed in the lower right hand corner of the map window. This
>> makes it easy to, for example, find the coordinates of an
>> intersection on a street map by simply moving the cursor over the
>> intersection and writing down the coordinates.
>> My problem is, is there any way to copy those coordinates to the
>> clipboard with a keystroke command so they can be pasted somewhere
>> else, rather than having to write them down by hand? I've tried the
>> usual ctrl-c / ctrl-x kind of things with the Pointer, Query, and
>> Measure tools selected, but nothing I try seems to put anything on
>> the clipboard.
>> Does anyone know the answer to this one (or is there another way to
>> do this using v.digit or something similar?)
>> Here's a link to a screenshot with the coordinate box highlighted in
>> case I haven't been clear:
>> https://php10.ucsf.edu/ufostudy/transfer/screenshot.html
> Query the map - the coordinates of where you clicked are in the gis.m
> output window then, even if no object was found. Copy & paste from there.
> Maciek
> Maciej Sieczka
> www.sieczka.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081230/c8c39f4d/attachment.html
