[GRASS-user] suppress output to terminal completely
Hufkens Koen
koen.hufkens at ua.ac.be
Mon Dec 29 20:14:48 EST 2008
I use the --quiet option but then the output changes from
tracing patch 1
tracing patch 2
etc...
to tracing patch 1 and then only flipping this number and not rewriting the line.
So it does not respect the --quiet option completely...
And the 2> /dev/null option seems to work, now my script can run in the background and I can keep working.
Thanks,
Koen
-----Original Message-----
From: Paul Kelly [mailto:paul-grass at stjohnspoint.co.uk]
Sent: Mon 29-12-2008 17:36
To: Hufkens Koen
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] suppress output to terminal completely
On Mon, 29 Dec 2008, Hufkens Koen wrote:
> Hi list,
> I'm working with r.le.patch in both scripts as well as interactively on the terminal.
> Since these calculations take up a lot of time I would like to move them to the background.
> If I use r.le.patch -mysettings & this will do just that.
> However, the module still spews stuff to my terminal. This is very annoying as I login remotely so I can't fall back on the GUI menus.
> Can I disable my terminal output completely?
> dumping stout to /dev/null does not seem to work...
GRASS modules send informative messages to stderr, not stdout - so adding
2>/dev/null
(Bash shell syntax) should work. But have you tried r.le.patch --quiet
first of all? I'm not sure if r.le.patch respects the --quiet setting, but
redirecting stderr to /dev/null definitely will work.
Paul
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20081230/d2c4ba75/attachment.html
