[GRASS-user] shell script problem
Jachym Cepicky jachym.cepicky at gmail.com
Tue Dec 30 02:43:03 EST 2008
isn't there any no-linebreak space somewhere?
j
2008/12/4, Otto Dassau <otto.dassau at gmx.de>:
> Hi Mario,
>  On Thu, 4 Dec 2008 17:46:36 +0000
>  "Mario Giacomello" <mario.giacomello at googlemail.com> wrote:
>  > Thanks for your prompt response. I have got as far as understanding
>  > that I should run scripts inside GRASS.So, the answer is "yes- I have
>  > run the script inside GRASS".
> try to start the script with:
>  sh grassscript.sh
>  or
>  ./grassscript.sh (if you made it executable)
>  regards,
>  Otto
>  > Marco
>  > On Thu, Dec 4, 2008 at 5:54 PM, ivan marchesini <marchesini at unipg.it> wrote:
>  > > hmmm
>  > > are you starting the script inside grass?
>  > > probably not... or I'm wrong?
>  > > Ivan
>  > > Il giorno gio, 04/12/2008 alle 17.06 +0000, Mario Giacomello ha scritto:
>  > >> Dear all,
>  > >> Apologies for the total beginner's question, but despite my efforts
>  > >> and searches through the GRASS mailing list archives I have not been
>  > >> able to solve my problem. I am trying to write a simple grass script
>  > >> in order to automated a process, but I have not very far yet. One
>  > >> thing that I would like to do is to be able to change the region, but
>  > >> GRASS seems to come up with the whenever I , for example, try to use
>  > >> the following simple lines:
>  > >> #!/bin/sh
>  > >> g.region rast=map1
>  > >> r.stats -ln map1 > file1
>  > >> The message I get is: "command not found". What am I doing wrong? Is
>  > >> this problem related to the setting of environment variables?
>  > >> I am using GRASS 6.3.0  installed on Ubuntu 8.10
>  > >> thanks in advance,
>  > >> Mario Giacomello
>  _______________________________________________
>  grass-user mailing list
>  grass-user at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
