[GRASS-user] shell script problem
Otto Dassau otto.dassau at gmx.de
Thu Dec 4 12:49:35 EST 2008
Hi Mario,
On Thu, 4 Dec 2008 17:46:36 +0000
"Mario Giacomello" <mario.giacomello at googlemail.com> wrote:
> Thanks for your prompt response. I have got as far as understanding
> that I should run scripts inside GRASS.So, the answer is "yes- I have
> run the script inside GRASS".
try to start the script with:
sh grassscript.sh
or
./grassscript.sh (if you made it executable)
regards,
 Otto
> Marco
> On Thu, Dec 4, 2008 at 5:54 PM, ivan marchesini <marchesini at unipg.it> wrote:
> > hmmm
> > are you starting the script inside grass?
> > probably not... or I'm wrong?
> > Ivan
> > Il giorno gio, 04/12/2008 alle 17.06 +0000, Mario Giacomello ha scritto:
> >> Dear all,
> >> Apologies for the total beginner's question, but despite my efforts
> >> and searches through the GRASS mailing list archives I have not been
> >> able to solve my problem. I am trying to write a simple grass script
> >> in order to automated a process, but I have not very far yet. One
> >> thing that I would like to do is to be able to change the region, but
> >> GRASS seems to come up with the whenever I , for example, try to use
> >> the following simple lines:
> >> #!/bin/sh
> >> g.region rast=map1
> >> r.stats -ln map1 > file1
> >> The message I get is: "command not found". What am I doing wrong? Is
> >> this problem related to the setting of environment variables?
> >> I am using GRASS 6.3.0  installed on Ubuntu 8.10
> >> thanks in advance,
> >> Mario Giacomello
