[GRASS-user] shell script problem
    Mario Giacomello
    mario.giacomello at googlemail.com
    Thu Dec  4 12:46:36 EST 2008
Thanks for your prompt response. I have got as far as understanding
that I should run scripts inside GRASS.So, the answer is "yes- I have
run the script inside GRASS".
Marco
On Thu, Dec 4, 2008 at 5:54 PM, ivan marchesini <marchesini at unipg.it> wrote:
> hmmm
> are you starting the script inside grass?
> probably not... or I'm wrong?
> Ivan
> Il giorno gio, 04/12/2008 alle 17.06 +0000, Mario Giacomello ha scritto:
>> Dear all,
>> Apologies for the total beginner's question, but despite my efforts
>> and searches through the GRASS mailing list archives I have not been
>> able to solve my problem. I am trying to write a simple grass script
>> in order to automated a process, but I have not very far yet. One
>> thing that I would like to do is to be able to change the region, but
>> GRASS seems to come up with the whenever I , for example, try to use
>> the following simple lines:
>> #!/bin/sh
>> g.region rast=map1
>> r.stats -ln map1 > file1
>> The message I get is: "command not found". What am I doing wrong? Is
>> this problem related to the setting of environment variables?
>> I am using GRASS 6.3.0  installed on Ubuntu 8.10
>> thanks in advance,
>> Mario Giacomello
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Ti prego di cercare di non inviarmi files .dwg, .doc, .xls, .ppt.
> Preferisco formati liberi.
> Please try to avoid to send me .dwg, .doc, .xls, .ppt files.
> I prefer free formats.
> http://it.wikipedia.org/wiki/Formato_aperto
> http://en.wikipedia.org/wiki/Open_format
> Ivan Marchesini
> Department of Civil and Environmental Engineering
> University of Perugia
> Via G. Duranti 93/a
> 06125
> Perugia (Italy)
> Socio fondatore GFOSS "Geospatial Free and Open Source Software" http://www.gfoss.it
> e-mail: marchesini at unipg.it
>        ivan.marchesini at gmail.com
> tel: +39(0)755853760
> fax (university): +39(0)755853756
> fax (home): +39(0)5782830887
> jabber: geoivan73 at jabber.org
