[GRASS-user] NVIZ problem
Maris Nartiss
maris.gis at gmail.com
Wed Dec 31 07:58:15 EST 2008
Hello,
current NVIZ is pretty picky about drivers and window managers (focus
policy). Try to disable automatically render display feature in NVIZ.
It may help.
Maris.
2008/12/30, Darrel Maddy <darrel.maddy at newcastle.ac.uk>:
> Hi all,
> I have just tried to install grass on Ubuntu 8.10 64 bit. Everything is fine
> apart from nviz, which only shows the image as I change position/zoom etc.,
> that is it goes blank when left alone! I have an ati 4870 and have tried
> both the latest catalyst drivers and the restricted drivers but to no avail.
> Interestingly it does the same thing running the native windows version
> under vista (32 bit) running as a VM in virtualbox.
> Has anyone else had this problem? Is there a solution or should I go back to
> 8.04?
> Thanks in anticipation of your help.
> Darrel
> Prof Darrel Maddy
> Newcastle University
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
