[GRASS-user] Grass WIN: DBF problem
Michael Barton
michael.barton at asu.edu
Fri Feb 1 13:28:36 EST 2008
On Feb 1, 2008, at 7:45 AM, Moritz Lennert wrote:
> On 01/02/08 15:27, Massimiliano Cannata wrote:
>> Hi Moritz,
>> you are right, I was using a previous relese, with the RC4 release
>> of wingrass it perfectly works.
>> I just add a new issue (bug?):
>> - the show table attribute button in the GUI does not work, i get
>> the following error:
>> "dbmi-dbf driver error: table ti_comuni doesn't exist error in
>> db_open_select_cursor()"
>> Table exist and works with the following commands:
>> - show attribute column GUI button works
>> - "database->query->query vector attribute table" perfectly works
>> from menu
> The 'show table attribute' button calls db.select. Look into the
> Output window to see what the database= option of this command is.
> Probably your general database setting is not correct. The other
> commands use the specific database settings of the particular vector
> map.
> Michael, any particular reason why it does not use v.db.select ?
I don't remember. Perhaps it didn't exist or didn't do the job when I
originally wrote this procedure a couple years ago. Do you think it
would work better than the current combination of v.db.connect (to get
info on database connected to vector) coupled with db.select?
Michael
> Run databases->manage database->connect to database (db.connect)
> with the 'print current connection parameters and exit' option and
> see what you get. If it is not correct, run the same command again,
> but without the print option and setting your correct database info.
> Moritz
