[GRASS-user] Grass WIN: DBF problem
Moritz Lennert
mlennert at club.worldonline.be
Fri Feb 1 09:45:07 EST 2008
On 01/02/08 15:27, Massimiliano Cannata wrote:
> Hi Moritz,
> you are right, I was using a previous relese, with the RC4 release of
> wingrass it perfectly works.
> I just add a new issue (bug?):
> - the show table attribute button in the GUI does not work, i get the
> following error:
> "dbmi-dbf driver error: table ti_comuni doesn't exist error in
> db_open_select_cursor()"
> Table exist and works with the following commands:
> - show attribute column GUI button works
> - "database->query->query vector attribute table" perfectly works from menu
The 'show table attribute' button calls db.select. Look into the Output
window to see what the database= option of this command is. Probably
your general database setting is not correct. The other commands use the
specific database settings of the particular vector map.
Michael, any particular reason why it does not use v.db.select ?
Run databases->manage database->connect to database (db.connect) with
the 'print current connection parameters and exit' option and see what
you get. If it is not correct, run the same command again, but without
the print option and setting your correct database info.
Moritz
