[GRASS-user] Re: GCC vs. locale
Glynn Clements
glynn at gclements.plus.com
Sat Feb 2 15:31:17 EST 2008
Ivan Shmakov wrote:
> > ASCII is a subset of UTF-8, so there's no problem with using the
> > ASCII quote characters in that situation.
> That's the problem -- ASCII lacks single quote characters.
It also lacks a decimal point character. But just as a full stop
(period) suffices as a decimal point, the apostrophe suffices as a
single quote character (e.g. C/C++, Bourne shell, etc).
It's not as if you actually *need* to use balanced quotes.
> PS. Is `utf8' a valid MIME charset name?
iconv understands it as an alias for utf-8. I don't know whether MIME
specifies an exhaustive list of encodings.
FWIW, the fact that VM chose UTF-8 was news to me; historically, it
has used ISO-2022 for multi-lingual text.
