[GRASS-user] Re: GCC vs. locale
Ivan Shmakov
ivan at theory.asu.ru
Sat Feb 2 08:25:58 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>>>>> driver.h:70: error: \u2018BOUND_BOX\u2019 does not name a type
>>>>> make: *** [OBJ.i686-pc-linux-gnu/grass6_wxvdigit_wrap.o] Error 1
>>>> "\u2018" -- unicode characters sneaking into what should be a flat
>>>> ASCII file?
>>> Those are just the quotes added by the compiler. Recent versions of
>>> gcc have taken to using gratuitous non-ASCII punctuation in
>>> diagnostic messages.
>> Is it due to a locale setting? It seems reasonable for GCC to put
>> UTF-8 quotes when asked for such a locale.
> ASCII is a subset of UTF-8, so there's no problem with using the
> ASCII quote characters in that situation.
That's the problem -- ASCII lacks single quote characters.
$ zcat /usr/share/i18n/charmaps/ANSI_X3.4-1968.gz
<code_set_name> ANSI_X3.4-1968
% alias ASCII
<U0027> /x27 APOSTROPHE
<U0060> /x60 GRAVE ACCENT
> It might be different if the locale was one which doesn't normally
> use "..." for quotations. E.g. using «...» in a French locale or
> 「...」 in a Japanese locale might be reasonable. But the error message
> was quite clearly in English.
> If it was using non-ASCII characters in the C/POSIX locale, that
> would be an unequivocal bug.
In C/POSIX locale (as well as in the rest of the ASCII world),
APOSTROPHE and GRAVE ACCENT are traditionally used to represent
single quote characters. However, there's no need in such a
behaviour when the character set has ``real'' single quote
characters.
$ zcat /usr/share/i18n/charmaps/UTF-8.gz
<code_set_name> UTF-8
% alias ISO-10646/UTF-8
CHARMAP
<U2018> /xe2/x80/x98 LEFT SINGLE QUOTATION MARK
<U2019> /xe2/x80/x99 RIGHT SINGLE QUOTATION MARK
> As it is, it's merely a poor choice.
I'd say that it's a behaviour consistent with that of other
applications. I cannot imagine a case where this behaviour
could be actually useful (other than inserting the program
output into a UTF-8 printed document), but it's consistent.
PS. Is `utf8' a valid MIME charset name?
Subject: Re: GCC vs. locale
Date: Sat, 2 Feb 2008 13:53:18 +0000
Message-ID: <18340.30158.625426.938920 at ...>
Mime-Version: 1.0
Content-Type: text/plain; charset=utf8
Content-Transfer-Encoding: quoted-printable
My Gnus seemingly misrecognized it.
