[GRASS-user] map display
Otto Dassau
otto.dassau at gmx.de
Wed Feb 6 04:22:19 EST 2008
Hi Christian,
you can try to change the region settings to fit the map extend (in command
line):
g.region vect=map -p
d.erase
d.vect map
the -p parameter shows the current region settings (coordinates, resolution,
etc.)
Regards,
Otto
On Wed, 6 Feb 2008 09:12:36 +0000
christian Brandt <chrisbrandt74 at hotmail.com> wrote:
> Dear list,
> I am quite new in the GRASS Gis environment and I've some problems with the
display of my features.
> My GRASS version is the 6.2.3 on Open Suse 10.2 (64 bit). After defining the
projection, importing the data (in this case a shape file) and entering the
d.vect command nothing is drawn on the display. I also tried the d.mon command
but no graphics are shown.
> Can anybody help?
> Regards
> Chris
