[GRASS-user] map display
Frank Broniewski
liste at geo-dienstleistung.de
Wed Feb 6 04:27:38 EST 2008
Hi Chris,
If you intend on using d.mon you should start a monitor with d.mon x0. Before
that, you should set the region extent. So doing
1) g.region vect=yourshpfile
2) d.mon x0
3) d.vect yourshpfile
should give you some results.
Same procedure should work for gis.m. Set your region first before drawing the
graphics.
Greetings
Frank
On Wednesday 06 February 2008 10:12:36 christian Brandt wrote:
> Dear list,
> I am quite new in the GRASS Gis environment and I've some problems with the
> display of my features. My GRASS version is the 6.2.3 on Open Suse 10.2
> (64 bit). After defining the projection, importing the data (in this case a
> shape file) and entering the d.vect command nothing is drawn on the
> display. I also tried the d.mon command but no graphics are shown.
> Can anybody help?
> Regards
> Chris
> _________________________________________________________________
> Express yourself instantly with MSN Messenger! Download today it's FREE!
> http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/____________
>___________________________________ grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
