[GRASS-user] Permission denied (again!)
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Feb 6 07:51:02 EST 2008
On Wed, 2008-02-06 at 08:13 +0100, Frank Broniewski wrote:
> I just want to confirm this 'behavior' with GRASS installed from Repositories
> on a Ubuntu 7.10 machine. We had the same error recently.
> GRASS had been installed and started with the -gui parameter. Creating a
> location within the homefolder fails for the same reasons already given
> below.
> However we were able to create a new location with the text based version of
> GRASS, but some of the gis.m modules (like the map window) cannot be used. As
> far as I remember, it gives some errors about region extend not being able to
> read. I would have to ask my colleague for details.
> Nearly two years back, I had the same problem and I found some kind of
> solution. I posted this on the list in year 2006. You can find the according
> threads here:
> http://www.nabble.com/-GRASS-user--Can't-create-location-td5691835.html
> It had something to do with write permissions on the tmp directory where GRASS
> creates the location.
YES... that's it!
Sorry for not reading this before.. I just replied to Hamish.
Ohhhhhhh... it's annoying :-|
Things like that happen ONLY when they should not... ! It's the deamon
that brakes things for which you are absolutely sure that work ;-) Or...
it's just our selective memory, emphasizing more on negative experiences
so we forget the positive one's.
> Hope this helps
I am checking it right away.
> Frank
> On Wednesday 06 February 2008 04:13:15 Hamish wrote:
> > nikos.alexandris wrote:
> > > Thanks for the quick reply. I need it cause we try to
> > > explore GRASS with a couple of friends and we got stuck on that(!)
> > > First of all:
> > > >grass
> > > Cleaning up temporary files.....
> > > Starting GRASS ...
> > > ERROR: MAPSET PERMANENT - permission denied
> > > Then any other attempt to create a LOCATION ends-up with
> > > exiting GRASS saying to re-log and find the newly created LOCATION...
> > > which is not there of course.
> > > I try to edit manually .grassrc6 but still no luck with the
> > > LOCATION creation.
> > if data was copied from a CD make sure that the GRASS database,
> > locations, etc. have been given back write permissions, recursively.
> > (the filesystem cares)
> > also check that the current user owns the mapset you are trying to
> > load. (by default GRASS lets you read from anyone mapset but only you
> > can write to your own)
> > for the file system test try going to where you are trying to make the
> > new location and create a new directory, files, etc. That is all GRASS
> > is trying to do and if you can do that as a normal user, and the same
> > user as starts grass6, GRASS should be able to it as well.
> > Also follow up that x-terminal-emulator error. Is this Ubuntu or
> > Debian?
> > What version(s) of OS & GRASS?
> > ls -l /usr/bin/x-terminal-emulator
> > ls -l /etc/alternatives/x-terminal-emulator
> > Hamish
> > ___________________________________________________________________________
> >_________ Looking for last minute shopping deals?
> > Find them fast with Yahoo! Search.
> > http://tools.search.yahoo.com/newsearch/category.php?category=shopping
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080206/2101e334/attachment.bin
