[GRASS-user] Permission denied (again!)
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Thu Feb 7 11:06:34 EST 2008
Hi!
On Thu, 2008-02-07 at 03:38 +0000, Paul Kelly wrote:
> On Tue, 5 Feb 2008, Nikos Alexandris wrote:
> > 2. Launching grass63 (release fetched with svn,
> > configured-compiled-installed) does not have any problems.
> Is that not a good solution to your problems then?
It is for me. Not for a couple of friends with which we had a common
GRASS session today... and they just installed current stable versions
from the Ubuntu repo's.
> The location creation
> through the start-up GUI was all very experimental prior to 6.3; a lot of
> things have been cleaned up since 6.2 - and the changes were too
> complicated and extensive to be easily backported.
> > My questions is:
> > What is the difference when creating a new LOCATION in text mode from
> > trying to do so with the GUI (EPSG's or Georef.file)?
> The GUI uses g.proj in the background; "Create using projection values"
> uses $ETC/set_data. They both create new locations but do so in completely
> different ways and the locations they create are slightly different in
> several subtle ways - hopefully these days we've ironed out most of the
> incompatibilities between them.
> But note that you can also run g.proj from
> the command-line if you want - check the man page for details; it has lots
> of options for creating new locations and the GUI is just another layer on
> top of this.
> Paul
Thank you all!
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080207/946e04f3/attachment.bin
