[GRASS-user] wxgui issue
Michael Barton
michael.barton at asu.edu
Tue Feb 12 12:12:51 EST 2008
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Feb 12, 2008, at 10:00 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Tue, 12 Feb 2008 14:28:55 +0100
> From: Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> Subject: Re: [GRASS-user] wxgui issue ( No module named wx)
> To: Carlos "Gu?no" Grohmann <carlos.grohmann at gmail.com>
> Cc: GRASS List <grassuser at grass.itc.it>
> Message-ID: <1202822935.6475.9.camel at vertical>
> Content-Type: text/plain; charset="utf-8"
> Just a POSITIVE comment!
> The new GUI looks awesome!
> Great job!
> Where should I direct my "wishes"?
> I miss the "add cell values layer"... ;-)
> Cheers to all wxgrass developers!
Thanks for the positive words on behalf of all of us working on this.
The cell values layer won't work currently because it depends on the
region resolution matching the resolution of the raster map.
(Perhaps this could be changed???)
Because the display resolution stays constant (regardless of the
underlying computational resolution) in order to render MUCH faster,
this means that even if you zoom in to a few cells, d.rast.num thinks
you have too many cells to display and won't work. I hope there is a
way to get around this eventually.
Michael
