[GRASS-user] Grass-6.3.0 errors during make
roberto caselli
roberto.caselli at yahoo.it
Wed Feb 13 05:29:57 EST 2008
Hi guys,
I'm installing Grass6.3.0 on my linux xubuntu 7.10 environment. At the end of the make process i received this output:
Started compilation: mer feb 13 00:20:17 CET 2008
Errors in:
/home/roberto/grass-6.3.0RC4/lib/db/sqlp
/home/roberto/grass-6.3.0RC4/db/drivers/dbf
/home/roberto/grass-6.3.0RC4/db/drivers/ogr
/home/roberto/grass-6.3.0RC4/raster/r.mapcalc
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: mer feb 13 01:45:01 CET 2008
make: *** [default] Error 1
roberto at ubuntu:~/grass-6.3.0RC4$
So I cd /home/roberto/grass-6.3.0RC4/lib/db/sqlp and a type make with this output:
flex lex.l
lex.l:35: bad character: %
lex.l:35: unknown error processing section 1
lex.l:35: bad character: 1
lex.l:35: bad character: 2
lex.l:35: bad character: 0
make: *** [lex.yy.c] Error 1
The version of Flex is 2.5.34.
The remaining directories /home/roberto/grass-6.3.0RC4/db/drivers/dbf, /home/roberto/grass-6.3.0RC4/db/drivers/ogr, failon the make with this output:
/usr/bin/ld: cannot find -lgrass_sqlp
collect2: ld returned 1 exit status
make: *** [/home/roberto/grass-6.3.0RC4/dist.i686-pc-linux-gnu/driver/db/dbf] Error 1
How can I fix them?
Thank you,
Roberto
L'email della prossima generazione? Puoi averla con la nuova Yahoo! Mail
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080213/930f89ed/attachment.html
