[GRASS-user] Display Of Tiff Raster file Stored on HDD in Grass
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Feb 13 03:19:54 EST 2008
Hi!
(Assuming you have created a LOCATION based on the coordinate system in
which you want to work and in which your data is projected...)
* Using r.in.gdal from the command line or from the GUI under
"File>Impor> Raster map> Multiple formats using GDAL"
* Important is to check the extent and the resolution of your current
working "region". If these settings are not the proper ones the you
don't see anything cause your data are somewhere out of your "screen"
but still inside your LOCATION.
a. With "g.region -p" in the command line or "Config>Region>Display
region settings" you can check the current seetings.
b. Fastest way is to tell r.in.gdal to "extend location extents based
on new dataset" (either with r.in.gdal -e input=... output=... and the
rest or by checking the respective option in the GUI of r.in.gdal)
Hope this helps you a bit...
On Wed, 2008-02-13 at 09:32 +0530, Kunal Malik wrote:
> I am a new grass user,I have Installed the grass-6.2.3 on my
> system.but i m not able to Import & display the raster image.(Tiff
> Image) which is kept on my hard disk 50 mb in size..
> could anyone tell the way to see the raster image,i am looking for the
> standard document for using grass.if anyone having this
> document,please forward it to me..
> Thanks in Advanc
> image.(Tiff Image)
> for the standard document for using grass.if anyone having
> this document,please forward it to me..
> Thanks in Advanc
> Thanks & Regards
> Kunal Malik
> 09871147561
> Thanks & Regards
> Kunal Malik
> 09871147561
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos Alexandris
Department of Remote Sensing & Landscape Information Systems
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080213/0e5807b7/attachment-0001.bin
