[GRASS-user] Re: strange behaviour of v.surf.idw
G. Allegri
giohappy at gmail.com
Wed Feb 13 06:05:57 EST 2008
I used -n flag. The surface is now more realistics and appears allineated to
the narrower IDWs results:
http://www.geospatial.it/allegri/IDW5.png<http://www.geospatial.it/allegri/IDW4.png>.
I can't access your PhD thesis...
Giovanni
2008/2/13, Luigi Ponti <lponti at infinito.it>:
> Dear Paul,
> I have found your PhD thesis excerpt very interesting: thanks for
> sharing it.
> > Date: Tue, 12 Feb 2008 21:31:44 +0000 (GMT)
> > From: Paul Kelly <paul-grass at stjohnspoint.co.uk>
> > Subject: Re: [GRASS-user] strange behaviour of v.surf.idw
> > To: "G. Allegri" <giohappy at gmail.com>
> > Cc: grassuser <grass-user at lists.osgeo.org>
> > Also, have you tried running using the -n flag (no indexing) and
> comparing
> > the results. I think they should be the same for all regions then but
> > might turn up something else interesting.
> I started using v.surf.idw (for irregularly spaced points) in grass6.0
> with no -n flag, then in 6.1 I noticed that the output raster changed
> from what it used to be (i.e., some stair-like artifacts appeared) and
> it was restored to the original look (i.e., a much smoother look) by
> adding the -n flag. By looking at your PhD thesis excerpt, it looks like
> the -n flag should only make the interpolation faster: I wonder if you
> have any idea why there may be differences, as you also say above.
> Kind regards,
> Luigi
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080213/9f8ee725/attachment.html
