[GRASS-user] Display Of Tiff Raster file Stored on HDD in Grass
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Feb 13 05:49:56 EST 2008
I forgot to cc to the list before... so once again, and this time more
clear:
* check the projection system information of your tif file with gdalinfo
from the commandline.
(man gdalinfo for help)
* and then... (the message I forgot to cc to the list):
You have to know in which coordinate system your "nf42_geo.tif" data is
projected. If you are sure that your data is projected in the coordinate
system which you assigned in your LOCATION
(with g.region -o you get that info as well)
then just use an extra option to ignore these errors:
-o in the commald line or the respective box in the GUI "Override
projection"
e.g. CLI: > r.in.gdal -e -o in=nf42_geo.tif out=tm
By the way,
it is very helpful and saves time and energy to consult tha help pages
always. There are (almost) always the necessary examples and
explanations.
On Wed, 2008-02-13 at 15:05 +0530, Kunal Malik wrote:
> Hi!!
> I have done the things required.
> but from the command line ,when i am using r.in.gdal -e
> -n=nf42_geo.tif out=tm ..
> I am getting the message
> WARNING: Datum 'unknown' not recognised by GRASS and no parameters
> found.
> Datum transformation will not be possible using this
> projection
> information.
> ERROR: Projection of dataset does not appear to match current
> location.
> Same messge is coming when I am doing the same through GIS Manager..
> Can u help me i this Regards..so that i could open the avalible TIf
> image
> On 2/13/08, Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> wrote:
> Hi!
> (Assuming you have created a LOCATION based on the coordinate
> system in
> which you want to work and in which your data is projected...)
> * Using r.in.gdal from the command line or from the
> GUI under
> "File>Impor> Raster map> Multiple formats using GDAL"
> * Important is to check the extent and the resolution of your
> current
> working "region". If these settings are not the proper ones
> the you
> don't see anything cause your data are somewhere out of your
> "screen"
> but still inside your LOCATION.
> a. With "g.region -p" in the command line
> or "Config>Region>Display
> region settings" you can check the current seetings.
> b. Fastest way is to tell r.in.gdal to "extend location
> extents based
> on new dataset" (either with r.in.gdal -e input=... output=...
> and the
> rest or by checking the respective option in the GUI of
> r.in.gdal)
> Hope this helps you a bit...
> On Wed, 2008-02-13 at 09:32 +0530, Kunal Malik wrote:
> > I am a new grass user,I have Installed the grass-6.2.3 on my
> > system.but i m not able to Import & display the raster
> image.(Tiff
> > Image) which is kept on my hard disk 50 mb in size..
> > could anyone tell the way to see the raster image,i am
> looking for the
> > standard document for using grass.if anyone having this
> > document,please forward it to me..
> > Thanks in Advanc
> grass-6.2.3 on my
> raster
> > image.(Tiff Image)
> am looking
> > for the standard document for using grass.if anyone
> having
> > this document,please forward it to me..
> > Thanks in Advanc
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> > Thanks & Regards
> > Kunal Malik
> > 09871147561
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Nikos Alexandris
> Department of Remote Sensing & Landscape Information Systems
> Faculty of Forestry & Environmental Sciences,
> Albert-Ludwigs-University Freiburg
> Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 /
> Skype: Nikos.Alexandris
> Address: Tennenbacher str. 4, D-79106 Freiburg i. Br., Germany
> Thanks & Regards
> Kunal Malik
> 09871147561
Nikos Alexandris
Faculty of Forestry & Environmental Sciences, Albert-Ludwigs-University Freiburg
Tel. +49 (0) 761 203 3697 / Fax. +49 (0) 761 203 3701 / Skype: Nikos.Alexandris
Name: not available
Desc: This is a digitally signed message part
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080213/545a270b/attachment-0001.bin
