[GRASS-user] where clause in v.extract for '*'
Hamish
hamish_b at yahoo.com
Thu Feb 14 02:11:43 EST 2008
Juan Miguel Garijo wrote:
> In a vector map there is a text field with values
> like:
> xxxx
> xxxx
> xxxx*
> xxxx(*)
> I need to select all values wich finish with '*' OR
> (without '')
> Wich 'where' clause can I use in v.extract?
> I see that is not the same if you write it in console
> or throu gis.m
> Driver:dbf
I don't know if there is a regex '$'-like character in SQL to denote
end of string match, but you can use
where COLUMN ~ '*'
to select strings which contain a '*' (? perhaps; I'm no SQL expert)
try looking in the SQL reference guide:
http://www.redhat.com/docs/manuals/database/RHDB-2.1-Manual/sql/sqlreference.html
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
