[GRASS-user] Projection of dataset does not appear to match the current location!!!
Jachym Cepicky jachym.cepicky at gmail.com
Thu Feb 14 04:19:15 EST 2008
Hi!!
Kunal Malik píše v Čt 14. 02. 2008 v 14:30 +0530:
> location!!!
this means, that your map is not in the same projection, as the
spearfish dataset is. you have to either:
* use -o flag for r.in.gdal, which will override the projection check
(use it only if you are sure, the map *is* in the same projection)
* create new location & mapset, which projection is the same, as the
file projection
* use the location= parameter in r.in.gdal, which will create new
location for you, with the projection according the raster file
* start GRASS with gui (grass62 -tcltk) and hit the "Georeferenced file"
button, which will create new location based on the projection values
from your tiff file
hope, this helps
jachym
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080214/b59291eb/attachment.bin
