[GRASS-user] Projection of dataset does not appear to match the current location!!!
Kunal Malik kunal.malik81 at gmail.com
Thu Feb 14 04:53:14 EST 2008
HI!!
following ur Instructions
I have created a new Location MAP:
Name of the New LOcation: Map
Path to New Location:/usr/local/grassdata/
Path to georefrenced file:/usr/local/grassdata/Path_to_Tiff_File
it create a new location Map..
Now i tried to Import tiff file selecting the Map Location...
r.in.gdal -e in=nf4.tif out=tm..
now it shows projection Matched
but I am not able to display it,,
how could i display it,,
please check the setting ,,is that rght?
On 2/14/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi!!
> Kunal Malik píše v Čt 14. 02. 2008 v 14:30 +0530:
> > location!!!
> this means, that your map is not in the same projection, as the
> spearfish dataset is. you have to either:
> * use -o flag for r.in.gdal, which will override the projection check
> (use it only if you are sure, the map *is* in the same projection)
> * create new location & mapset, which projection is the same, as the
> file projection
> * use the location= parameter in r.in.gdal, which will create new
> location for you, with the projection according the raster file
> * start GRASS with gui (grass62 -tcltk) and hit the "Georeferenced file"
> button, which will create new location based on the projection values
> from your tiff file
> hope, this helps
> jachym
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Thanks & Regards
Kunal Malik
09871147561
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080214/1cf5b99c/attachment-0001.html
