[GRASS-user] Projection of dataset does not appear to match
the current location!!!
Jachym Cepicky
jachym.cepicky at gmail.com
Thu Feb 14 05:03:00 EST 2008
hi,
should work
so,
I do not know, if you are using GUI or CLI
in CLI:
g.list rast # gives you list of available raster maps
d.mon x0 # start grass monitor
d.rast your_map # displays raster file called your_map
in GUI:
hit the "Add raster layer" button
in new form, click at the "Base raster layer" button in GIS Manager and
choose your map in list of available maps
you can also write "g.list rast" in GRASS Output window and see the list
of available raster maps.
anyway, maybe now is good time to start to read some book ..?
http://www.grassbook.org/
http://gdf-hannover.de/dl.php?download=gdf_grass60_v1.2_en.pdf
jachym
Kunal Malik píše v Čt 14. 02. 2008 v 15:23 +0530:
> HI!!
> following ur Instructions
> I have created a new Location MAP:
> Name of the New LOcation: Map
> Path to New Location:/usr/local/grassdata/
> Path to georefrenced file:/usr/local/grassdata/Path_to_Tiff_File
> it create a new location Map..
> Now i tried to Import tiff file selecting the Map Location...
> r.in.gdal -e in=nf4.tif out=tm..
> now it shows projection Matched
> but I am not able to display it,,
> how could i display it,,
> please check the setting ,,is that rght?
> On 2/14/08, Jachym Cepicky <jachym.cepicky at gmail.com> wrote:
> Hi!!
> Kunal Malik píše v Čt 14. 02. 2008 v 14:30 +0530:
> > Projection of dataset does not appear to match the current
> > location!!!
> this means, that your map is not in the same projection, as
> the
> spearfish dataset is. you have to either:
> * use -o flag for r.in.gdal, which will override the
> projection check
> (use it only if you are sure, the map *is* in the same
> projection)
> * create new location & mapset, which projection is the same,
> as the
> file projection
> * use the location= parameter in r.in.gdal, which will create
> new
> location for you, with the projection according the raster
> file
> * start GRASS with gui (grass62 -tcltk) and hit the
> "Georeferenced file"
> button, which will create new location based on the projection
> values
> from your tiff file
> hope, this helps
> jachym
> Jachym Cepicky
> e-mail: jachym.cepicky gmail com
> URL: http://les-ejk.cz
> GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
> Thanks & Regards
> Kunal Malik
> 09871147561
Jachym Cepicky
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080214/1e7f068f/attachment.bin
