[GRASS-user] A couple of question about NVIZ
Hamish
hamish_b at yahoo.com
Thu Feb 14 19:11:06 EST 2008
Aldo Clerici wrote:
> I have a couple of questions about NVIZ (GRASS6.2.3 and 6.3)):
> 2) In File > Save image as...> Maximum Resolution PPM, the image is
> saved in a file with '..the highest resolution (size) supported by
> the users graphics setup'. Is there a way for the user to set the
size
> (in cm or inches) or the size is fixed?
For the main pic you can do File -> Set canvas size
For the max res PPM you can only shrink it. To do that load it into
Gimp or some other program and Image->Scale Image (cubic method is
best).
>From the command line you could use pnmscale from NetPBM tools.
Hamish
____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
