[GRASS-user] A couple of question about NVIZ
Aldo Clerici
alcl01 at unipr.it
Thu Feb 14 11:11:46 EST 2008
Dear NVIZ-GRASSusers,
I have a couple of questions about NVIZ (GRASS6.2.3 and 6.3)):
1) What's the meaning of the flag -x and parameter path in nviz command?
-x should 'Start in Demo mode', but nothing seems to happen.
path should 'Set alternative panel path' but I don't understand which kind
of panel is referring to.
2) In File > Save image as...> Maximum Resolution PPM, the image is saved in
a file with '..the highest resolution (size) supported by the users graphics
setup'. Is there a way for the user to set the size (in cm or inches) or the
size is fixed?
Many thanks in advance
A.Clerici
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20080214/8527512c/attachment.html
