[GRASS-user] Re: Command line (bash) for Windows grass?
WolfgangZ
wollez at gmx.net
Sun Feb 17 15:25:59 EST 2008
Jonathan Greenberg schrieb:
> I've switched to using the mingw version -- msys comes with a command
> line "sh.exe", but I can't seem to a) boot grass using it, and b) and
> suspicious it won't be able to run bash scripting (sh is not the same as
> bash, correct?)
> --j
can you please report in detail what software versions you use! grass,
msys, mingw, ...
Otherwise it is really hard to figure out your problem.
Wolfgang
