[GRASS-user] trouble with dbf under WINGRASS
Niels Thevs nt001582 at uni-greifswald.de
Mon Feb 18 07:15:19 EST 2008
Oh sorry, I meant GRASS 6.3. RC4, dating from Jan 15th 2008. Two more
thing appeared: r.to.vect did not produce a dbf file. When I wrote a
script as txt file with r.mask, there was an error message: r.mask
command not found. This happened under Q-GIS with the GRASS shell as
well as in GRASS.
Best regards
Niels
Moritz Lennert schrieb:
> On 15/02/08 22:05, Niels Thevs wrote:
>> Dear all,
>> last week we had a workshop about WINGRASS (grass 6.3 CR$) and Q-
>> GIS (0.9.1) with students who use satellite images for their theses.
>> We used 20 computers all with the same software WINGRASS (grass 6.3
>> CR$), MSYS, TCL 8.4, and Q-GIS (0.9.1). We encountered the following
>> problems with the dbf files:
> Thanks for the feedback. What does 6.3 CR$ mean ?
>> On 2 out of 20 computers no dbf file was written when we imported
>> shape files into GRASS.
>> We were not able to use v.to.db to cvalculate areas of polygons.
>> The commands to add or remove columns did not work.
>> When we intersected vector layers about 4 out of 20 computers did not
>> wirte a new dbf file for the intersection result.
> This sounds like a problem with the dbf driver which should be corrected
> in the RC4 release.
> Are you sure all computers are using the same software ? Are there any
> other differences between computers (OS ?).
> Moritz
Dr. Niels Thevs
Chair of Geobotany and Landscape Ecology
Institute of Botany and Landscape Ecology
Greifswald University
Grimmer Strasse 88
17487 Greifswald
Germany
Tel.: +49-3834-86-4137
Fax:  +49-3834-86-4114
