[GRASS-user] trouble with dbf under WINGRASS
Hamish hamish_b at yahoo.com
Mon Feb 18 23:32:55 EST 2008
Niels Thevs wrote:
> Oh sorry, I meant GRASS 6.3. RC4, dating from Jan 15th 2008. Two more
> thing appeared: r.to.vect did not produce a dbf file. When I wrote a
> script as txt file with r.mask, there was an error message: r.mask
> command not found. This happened under Q-GIS with the GRASS shell as
> well as in GRASS.
I am not sure, but r.to.vect may only create a DB file if one is
needed. If the attributes are just x,y(,z) and a category number there
is no need for a DB and so none may be written.
Or did r.to.vect fail with an error?
FWIW r.mask is a UNIX shell script. Are other script modules like
r.shaded.relief there & working?
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
