[GRASS-user] v.split: Strange behaviour
Jachym Cepicky jachym.cepicky at gmail.com
Mon Feb 18 12:38:58 EST 2008
hi,
what about v.edit ?
# new file with vertexes
v.to.points in=roads out=tmp -v
# copy original file
g.copy vect=roads,myroads
# run v.edit
for line in `v.out.ascii tmp`; do
     eval `echo $line|sed -e "s/^/x=/" -e "s/|/; y=/" -e "s/|.*//"`;
     echo $line;
     v.edit -t map=myroads tool=break coords=$x,$y >/dev/null 2>&1;
done
well, it is not the best solution, but seems to work, but it failed for
me after 39 vertexes :-/
jachym
Craig Leat píše v Po 18. 02. 2008 v 12:08 +0200:
> Hi
> I have a vector map where many lines have vertices. I wish to replace
> all vertices with nodes, so I tried:
> v.split in=sewer_SS out=sewer_split ver=2
> The output is not what I expect in two respects:
> 1.  The attribute table has been dropped.
> 2.  I find that many lines are sharing the same cat, when cat should be
> unique. Some of the lines with a common cat are not even connected to
> the others.
> I am puzzled! Can anyone shed some light on what's going on here? I am
> using 6.3.0RC3 and sqlite.
> Regards
> Craig.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Jachym Cepicky
e-mail: jachym.cepicky gmail com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
	=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
	=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20080218/532e9426/attachment.bin
