[GRASS-user] v.split: Strange behaviour
Craig Leat
craig at pid.co.za
Thu Feb 21 04:39:12 EST 2008
Jachym Cepicky wrote:
> hi,
> what about v.edit ?
> # new file with vertexes
> v.to.points in=roads out=tmp -v
> # copy original file
> g.copy vect=roads,myroads
> # run v.edit
> for line in `v.out.ascii tmp`; do
> eval `echo $line|sed -e "s/^/x=/" -e "s/|/; y=/" -e "s/|.*//"`;
> echo $line;
> v.edit -t map=myroads tool=break coords=$x,$y >/dev/null 2>&1;
> done
> well, it is not the best solution, but seems to work, but it failed for
> me after 39 vertexes :-/
Hi Jachym
An interesting idea - thanks for the suggestion. I have found many
problems with my table (e.g one record pointing to many lines and some
records not pointing to any lines) so I decided to dump the table and
start from scratch. v.split worked well and so I have been able to clean
up the lines quite easily. I think the ability for v.split to update the
table by creating new records for each new line segment would be a GREAT
feature.
Regards
Craig
