[GRASS-user] Interpolation with faultlines?
Moritz Lennert mlennert at club.worldonline.be
Thu Feb 21 07:41:27 EST 2008
On 13/02/08 18:40, G. Allegri wrote:
> It's the same question I was going to ask. It would be an important
> advance in Grass, as I'm obliged to use commercial sw to do it (Esri)
> both to interpolate with barriers and to do 3D TINs with constraints.
The answer was (and as far as I know still is) to either run v.surf.rst
several times, once for each part within fault lines (using mask) or to
use r.surf.nnbathy (AddOns).
Moritz
